Hi I have taken on a repair for a mates friend after a two year strip down by some one else. the tractor is in Australia model 765 and has the s/n ANDY W592903
it was striped down for power divider failure the pump is worn but at this stage looks ok,It is the early type can not be pressure tested, all other parts look ok.the clutch pack has not been removed or checked.
My questions are ?(1)it looks like the gearbox needs to be taken off and striped down to remove the clutch pack.
(2) do these packs give many problems.
(3) and what should I be looking at for when I strip it down (problem wise)
Thanks
Thanks
