Okay folks. I've purchased a frozen up John Deere 60. I elevated the tractor about 18 inches or so off the ground. I pulled the plugs and put about 8 ounces of
Automatic Tranny Fluid in each cylinder and then topped it off with Diesel to let it sit a while. While it's sitting to soak, is there any pros or cons to taking
some of the same mix of ATF and diesel fuel and pouring it into the intake and exhaust manifold? I am thinking of trying it just to loosen up and free up any
valves etc while the other stuff sits in the cylinders. Should I? Would it help or cause problems? Thanks
