Case 930 CK throttle
CaseIH244930
New User
I recently purchased case 930 comfort king the tractor will run but only due to fuel with cut off valve. the thortlle linkage is moving the control at the injection pump but it does not make the tractor rev up or make any difference. And was wondering if anyone knew anything about the problem and how it has to be fixed :?:
Depending on the placement of the inj. pump, you might be able to remove the side cover on the pump.
Its just 2 10mm screws or 2 4mm allan screws..
Remove the side cover and pull the stop cable back and forth to make sure the control sleeves move back and forth..
Another thing to check is the throttle lever itself.. its connected to the governor by a D slot..
The shaft pokes thru the housing and the lever is cut w/ a D to slip over the shaft..
ALOT OF X's the bolt will come loose and the lever will spin on the D.. the lever will move but wont be turning the shaft..
Have you removed the bowl on the lift pump?? Most of them have one.. it has a plastic filter in it..
If the filter gets clogged, it has enough fuel to idle but that's it..
Good luck..
Remove the round cap at the front of the pump, takes a 19MM wrench on the flats. See if the rack moves when the throttle lever is moved from stop to wide open, you should see the rack move in and out, if not there's at least one or more plungers stuck. The throttle lever won't have slipped unless the center bolt has come loose, you have the early style shaft, not the late slotted shaft. If the rack is stuck DON'T beat on it, or rack and control sleeve damage may result..
