TEA 20 breather
AdamIce
New User
Hi
I'm fairly new to the vintage tractor scene but I've just completed a 1957 MF35 restoration and currently working on a 1950 TEA 20 but there's a part I am struggling to get and I don't actually know what its called !
I believe it to be a breather pipe from the engine to the air filter with a banjo fitting on the end but the banjo bolt is missing. Can anyone help me locate this part ?
many thanks
Adam
Hi Adam
Looks like you have two possibilities. There are two banjo bolts that fix to the block.
If you go to "Agco parts books Online" search the tea 20 tractor book, and then search "Banjo" they will come up. figure out which one you need, and maybe we can find one? It helps to have the part number.
Wayne
# 10...353 665 X1 Union(Banjo Type Screw)
# 11...825 293 M1 Washer 5/8 x 7/8 1/16" (Fibre)
# 37....825 083 M1 Pipe assembly (Suction to block)
Bob...
Thank you Gents
The images are a big help John its the 353 665 X1 Union(Banjo Type Screw)that I require.
Cheers Adam
I think you have the wrong part number there on no 10? the part number I get is 825205m1.
353665x1 comes up on the same page as the rear seal retainer bolts.
Ferguson has upgraded some of their old part numbers.
825205m1 is quite possibly the current part number.
353 665 X1 was the correct part number when Parts Book # 693 041 M2 was printed.
Bob...
