8120 hyd issue
LJH
New User
Anyone good with MF hyd issues? I purchased a used MF 8120 and it has a hyd issue I cannot resolve, it overheats due to the High pressure pump not cycling off. This can be initiated with turning the steering wheal or using one of the hyd lift levers. The pump will go back to nutral if tractor is shut off and restarted, any thoughts?
