BuckskinRider
New User
The Welch plug was missing off the bottom of the cast steering section. In order to install one I had to remove "some" parts so as to remove the entire steering column. As a result I'm now also replacing all the wiring, gauges, and steering wheel - cleaning thoroughly and repainting. The one thing I'm not certain about is after having removed the steering, and losing some hydraulic fluid, do I need to do anything special regarding bleeding or air, or is it a matter of running the tractor, turning the steering, and then adding fluid to it's proper fill level after reassembly?
Thanks in advance.
Thanks in advance.
