i have tried to hook up a std temp gauge to the sideport between block and radiator. there is a 5/8 18 turn/in bolt that was fitted with a nipple to accomodate the long probem itself.
result: no go! somehow the probe does not bath in the entire water? i will try to stick it into the radiator cap when hot to see if its the probe itself....but the probe was new when bot!
is there another port on a TO30 block or a t-piece to the hose connector between block and radiator that would accomodate a probe?
any help advice welcome!
fred
fred
