Farmall 450D pistons and sleeves
Rod Hauer
New User
I just picked up an old farmall 450 diesel and found out today that pistons and sleeves are not available through yesterday's tractors or two of their other sources that are frequently used. I'm wondering if anyone knows of a source that could be called on? Thank you in advance for any help you can provide.
On occasion the sleeves are bored and sleeved down to match the diameter of the worn pistons. if the pistons ring grooves are worn the grooves are cut for wider rings.
I am ivor from uk
there is a reputable firm that manufacture liners and there is no minimum order
and there is another firm that keep a lot of obsolete engine parts
(quoted from post at 14:08:28 08/22/16) I just picked up an old farmall 450 diesel and found out today that pistons and sleeves are not available through yesterday's tractors or two of their other sources that are frequently used. I'm wondering if anyone knows of a source that could be called on? Thank you in advance for any help you can provide.
http://weberstractorworks.com/ has them listed
