I have ford 600 starter wont engage. Tractor will run when pulled to start.
The starter spins fine when hooked up to battery off the tractor.
The starter button on the transmission has been checked and operates correctly.
The solenoid has been replaced and power to it changes with the key is turned on and off.
The battery test good and shows 12 volts. All the cables look good and have been cleaned at the connections.
Put it all together and No start! No click! No spin! No Nothing!
It acts like it's not getting power but it is. Maybe a flat spot in the starter?
HELP I'm at a loss for what to do next and don't want to just throw parts and $$$$$ at it.
