wiring diagram
I need a wiring diagram for a side mount 8N with 12 volt negative ground and a 2 wire alternator. I have seen some for a one wire alternator but not two wire. This must not be a true 12 volt coil as a resistor appears to have been used. Thanks
Take the diagram for one wire alternator. On the Plug on the edge pin,#2 can loop down to the output stud. #1 goes to output of ignition switch with a lamp or diode in the line. marker band on diode toward alternator. 3 amp @50volt diode would work. You can get the plug from any auto parts store
Sinse the 8N never came with an alternator, there won't be a factory wiring diagram available. You will need to adapt what you have to what was originally offered.
Here is a good view of what it will look like:
10SI wiring diagram
(quoted from post at 12:29:51 08/27/16) Sinse the 8N never came with an alternator, there won't be a factory wiring diagram available. You will need to adapt what you have to what was originally offered.
10SI wiring diagram
orry, Steve, but that diagram will only confuse him. Simply not 8N enough.
Never heard of a 2 wire you have to have 3 or it will not work correctly.
That said to wire it up is easy. You have the 2 wire plug. The #1 wire goes to the ignition switch the side that is hot when turned on with a diode or light bulb or resister in line so you can shut it off. The #2 wire goes to the charge stud on the alternator and the charge wire goes to the battery side of the amp gauge.
(quoted from post at 12:48:50 08/27/16) Never heard of a 2 wire you have to have 3 or it will not work correctly.
....but of course, he will NEVER see a charge indication on the ammeter!
