Best Thread Sealant For Fuel tank Shut-off valve
sweep
Putting in a new shut off valve in my Ford 2000 tank-gas.
What is recommended for thread sealant.
Thanks
"Gasoila" is as good as it gets, I use the "hard set" version which helps keep the joint from loosening from vibration.
Any of it will work, and there's lots of similar products out there.
Gasoila
I use Permatex foam a gasket and just a little on threads. Gasoline doesn't effect it and it seals without getting hard making it easy to take apart if needed.
