case 1030 fuel prime
Turn on fuel at tank.Loosen cap for venting. open primary filter bleed screw till fuel runs out.Close. Then open secondary filter
bleed screw till fuel comes out. Close. Should then start. If not crack a couple(any 2 or 3)injectors,crank till fuel squirts.
Tighten. Tractor should run. This is a 'universal' method. Your 'mileage' may vary.
Have you got 2 or 3 filters?? Open bleed screw on first filter and use the hand pump to fill the first filter, and the next and the third stage filter if it has
one. Sometimes junk fills the primer pump and it has to be taken apart and cleaned to work properly.
