why is ignition light on but still charging
I am ivor from uk and I have a matbro teleram 3 loader I am sure someone can explain why the ignition light is on when running but joystick and shuttle control working and starting ok
Ignition light?? Are you maybe talking about the charge idiot light?? As in the light should be out if the charging system is working as it should be??
If yes then that can be caused by an alternator that is getting weak and not putting out like it should be. Had that problem on a Chev car one time and the what ever it was that was going bad did not stop working for years and we just ran it that way
Do you have an amp guage. It may be a light to show you its charging or could just be a light to show you the key is on.
Could be just the indicator. I have a Kubota that's been doing that for at least five years. Unless the tractor sets for a very long time it starts just fine.
