Oil pressure drop ford 226 h
This message is a reply to an archived post by 48fotdgmail.com on April 21, 2016 at 16:58:11.
The original subject was "Re: Oil pressure drop ford 226 h".
Ok,I finally pulled motor.Removed main bearing cap,bearing is worn down to copper.Rod bearing cap removed also worn.Pulled bearings out,they say 0-.030 Can someone explain this to me,how do I know if this engine can be rebuilt?
48fotd,Take the crankshaft to a good automotive machine shop and have them mic and check the journals to see if it is within specs.It has all ready been turned to .030 under size and they can tell you if .040 or .060 under size bearings are available for it and it can be machined again.Also check the camshaft bearings in the block for being worn,as oil pressure loss can also be from worn camshaft bearings.
(quoted from post at 08:07:42 07/01/16) 48fotd,Take the crankshaft to a good automotive machine shop and have them mic and check the journals to see if it is within specs.It has all ready been turned to .030 under size and they can tell you if .040 or .060 under size bearings are available for it and it can be machined again.Also check the camshaft bearings in the block for being worn,as oil pressure loss can also be from worn camshaft bearings.
Thanks,if the crank is good and I go with .040 just say,will it be worth a rebuild?
Yes ,if the crank can be turned to .040 or .060 and you can get bearings for it the crank will be as good as a new one as far as running and oil pressure goes.Don't forget to check the cam bearings to.
(quoted from post at 12:26:51 07/01/16) Yes ,if the crank can be turned to .040 or .060 and you can get bearings for it the crank will be as good as a new one as far as running and oil pressure goes.Don't forget to check the cam bearings to.
ok, thanks again,have a nice weekend
Opinions will vary, but .030 is about the limit for turning a crank and expecting to get much life out of it. Anything more is pretty much reserved for rare engines, or something that sees little run time.
Crank journals are "case hardened". Which means the outer surface only is hard enough to maintain a bearing surface. Once the surface has been ground beyond .030, that hard surface is getting very thin.
If possible, your best bet is to find a crank that has not been turned, have it miked, polished if in tolerance, or turned to first under, which is .010.
(quoted from post at 20:26:53 07/01/16) Opinions will vary, but .030 is about the limit for turning a crank and expecting to get much life out of it. Anything more is pretty much reserved for rare engines, or something that sees little run time.
Thanks,that was my concern the life expectancy and cost involved to repair
The Ford cranks at that time were cast & not case hardened. It should run a long time at .040 if kept clean with good oil & changes.
(quoted from post at 10:51:02 07/02/16) The Ford cranks at that time were cast & not case hardened. It should run a long time at .040 if kept clean with good oil & changes.
That's good to know thanks for that
Good oil for flathead,you are talking non detergent,correct?
