trying to find kit for Marvel Schebler Carb
gbm321
New User
I just bought a Massey Ferguson 35 Deluxe serial # 232915. I believe that makes it a 1962 model. It has a Marvel Schebler Carb and I am trying to get the right rebuild kit for it. The tag on the carb reads 62 G. I can not find this number for a kit anywhere. The bottom of the carb is stamped 10 A 355. Can anybody help me find the proper rebuild kit for this carb? Thank you. :?
Kit for the M/S carbs are easy to find. So is the brass tag missing off of it which would be on the engine side so you have to have it off to read the tag?? That said if you have a local O'Reilly's they sell a walker brand kit that covers the 4 common size M/S/ carbs and being a 35 likely to be the 778-505A carb kit which has the gaskets etc for both the small and medium M/S carbs
My problem appears to be the numbers are no longer visible on the tag. I used your information and went to O,Rileys and got the kit. Thanks for your help.
