Ford 2000 1964 hydraulics
1964 Ford 3 point hydraulics aren't working. The pump seems to be working...I replaced the shaft seal. The wire to the 3pt pl as te on the left of the tractor was kicked...I Rewired it and it worked for a little bit...now not working...when I crank the engine fluid comes up in the pump drain hole. Thanks
(quoted from post at 23:12:25 06/08/16) 1964 Ford 3 point hydraulics aren't working. The pump seems to be working...I replaced the shaft seal. The wire to the 3pt pl as te on the left of the tractor was kicked...I Rewired it and it worked for a little bit...now not working...when I crank the engine fluid comes up in the pump drain hole. Thanks
point wiring on 2000 tractor?? Wonder what that is all about?? :roll:
