I have a 1927 1.5hp john deere hit and miss. Bought it at an auction, and have learned enough to make it run. Having trouble with oil leaking from the crankshaft bearings and around the magneto. Have taken it apart and installed new gaskets with sylicone, with not much gained. I have not taken the crankshaft and flywheels off the machine yet. Are there gaskets in there that should be replaced? The engine also will spit oil out of the the crankcase breather on the top. By the operators manual, I believe I have the correct amount of oil serviced into the crankcase. Anyone with some pointers out there? Thanks in advance!!
