Hi, beyond engine/trans how about things like
water pump housing
distributor housing
steering shaft nut at front end (worm gear just inside)
steering column to frame bolts
rad mounting bolts
light bar u-bolts
and anything else you can think of as this H is being fully disassembled (not engine or trans and not breaking in two) but pretty much anything hanging onto the frame is coming off to be completely re-done.
Have torque wrench must play. Thanks, Jack
water pump housing
distributor housing
rad mounting bolts
light bar u-bolts
