3010 john deere gas oil pan
wray54
New User
I've got a 3010 john deere and I need to install new rod
bearings, But I can't get the oil pan off. I've tried everything and
it won't budge. All the bolts are out and it won't move. Is there a trick to it?
Please help.
Did you remove the oil filter and oil filter can from the oil pan?
And all the bolts around the pan and the 6 that bolt it to the bell housing correct?
If you did all that it could be glued on really well, but should pop off.
