i464 problem
keaton22
New User
have i464 that acts like its not hitting on all cylinders when it doesn't have a load on engine. runs normal when it has a load on it, but without a load it will run normal for a minute then miss for a minute. runs like that whether the engine is hot or cold. not sure what's causing this?
Start with all the normal culprits...
Plugs, wires, cap, rotor, point gap and condition, distributor wear, carb condition and idle mix adjustment, throttle shaft wear, vacuum leaks, valve adjustment, broken valve spring, compression test.
These are not in any particular order, nor am I saying replace everything, just places to look.
the plugs and wires are new. has new electronic ignition. will check the others to see what I can come up with. Thanks!
