farmall super A rear axle end play
neelbert
New User
I've replaced all the seals and brg in both final drives . there was end play when I tore it down and still has end play. The parts break down shows no shims . When you tighten the inside bolt it hold everything tight on the axle. the brg are moving in the final drive housing . Looks like it could be shimmed between the outer seal retainer and brg. but none are on parts break down. Is there a fix for this thanks Neel
(quoted from post at 05:48:55 05/05/16) I've replaced all the seals and brg in both final drives . there was end play when I tore it down and still has end play. The parts break down shows no shims . When you tighten the inside bolt it hold everything tight on the axle. the brg are moving in the final drive housing . Looks like it could be shimmed between the outer seal retainer and brg. but none are on parts break down. Is there a fix for this thanks Neel
I would be interested to see the replies to this. Good post and will help folks in the future.
