Oliver 1800 hydro fluid leak from 1000 pto
IS there any way to turn off whatever your phone is doing to your spelling? Pro cove? Do you mean the round tin cap above the PTO shaft or are you talking about something else?
There's a thick o-ring in there that you'll probably have to get from an Agco dealer. I can recommend one that will mail one to you if you want me to. O-rings from an auto parts store assortment are too thin and will continue to leak.
Pop that plug out with a screwdriver. You'll find a snap ring in there inside the splines. Take that out,then take a piece of 1/2 inch coarse threaded rod or a long half inch bolt. Stick that in there and screw it in to the plug that's beyond that snap ring. Pull the plug out and the offending o-ring is in a grove in those splines.
Well there is also an oil seal that seals the PTO sleeve. You will need to determine if the oil is leaking from inside the splined sleeve or from the outside of the sleeve. You post an e-mail or a phone number I can send you a picture. That is the engine speed PTO and not a 1000 RPM PTO. It turns the wrong direction for one thing.
