Injector Pump Mounting Bolts MF 35 3 cylinder Perkins
ekhaithc
New User
I messed up and now need some help. I rounded off one of the injector pump cover mounting bolts ( located on top of pump). I have been looking to see if there is anywhere I can get a replacement without buying the whole pump but am unable to find it online. Does anyone know where these can be found at or what the specs on the actual bolt are? This is on a 59 Massey 35 Deluxe with a 3 cylinder perkins.
The top cover is held down with two acorn type nuts, takes a 3/8 inch wrench. I have the nuts used, and the studs too if you have one damaged. E-mail is open on Classic if you want to get in contact.
Yes i would definitely like to get in contact about getting one of the studs from you. Im new at this site and not really sure where to go to find your email. Is it supposed to be listed in your profile?
