carb reassembly
Dsmythe
What if anything do I need to put on the brass threads as I reassemble the carb?
Also, Will Never-Seez work on the manifold bolts and studs. We used it to coat Extruder bolts when we reassembled them after tear down and clean-up. It is GRAY.
Thank you all again for your help/advice.
For the carb body to bowl screws, I use nothing.
The screws that hold the choke and throttle plate to the shaft need either Lock-tite or the end bradded to prevent them from coming out.
For intake bolts I use nothing. For exhaust bolts high temp anti-sieze, or teflon tape.
