outbackrider400
Found a hercules 4 cylinder IXK engine '46 that was rebuilt in '73.
Machine shop tags still attached, pistons still have factory inventory
numbers on the piston heads. Everything inside looks good from looking
in the spark plug holes. Was never reinstalled.
I sprayed some pblaster in the cylinders
and put a little force on the crank and it turned over, I would say
it was mildly stuck from sitting for 43 years.
I have only turned it only a few times by hand crank. I am planning to
drop the pan and and oil up the bearings, etc. maybe
drop some 2 stroke oil into the cylinders, any suggestions on what else to do?
Stuffed in top of the manifold was a paper dated April '73
"Hank Aaron drove in 3 runs with his 674th career home run"
