Ford 841 lift cover
BillP
New User
While I was removing the hydraulic cylinder from the lift cover I felt something drop out from the accessories cover plate. I had the cover turned upside down on a bench. I had removed the accessories plate, the check valve plug, valve, plug. spring and steel ball. I did not remove the valve seat or the back pressure valve. I felt something drop and latter found a steel ball measuring .196 diameter. I have looked on the parts sheet and repair books to see if there is a steel ball of this size. Can anyone help with this ? Thanks.
I think it is
Number 26
