I have a 3000 with a select o speed that creeps forward in any gear including R1 and R2 this is with the release pedal pushed. when not pushed i have all gears and they don't seem to slip but it does seem to load the engine in some gears. From what i have read i am thinking i have a direct clutch issue since the extra engine load seems to be the worst in R2, 3,4,7,8,10. Does this make sense or am I thinking wrong?
I have also just gone through and changed the fluid, checked pressures and adjusted bands. I had to repair the upper valve block to realign the cam shaft and detent so valves would be positioned properly.
Thanks in advance for any expertise on this unit.
Also parts seem to be hard to find any recommendations?
