Rough Draft
Hey guys been lurking a little while first time posting. I have a case 930 CK 6 speed diesel. I've got a ez loader on it and for the longest time its been a little weak. Last spring i'm told the filter was cleaned (i'm skeptical). The problem i'm having now though is the hydraulic pump is making an awful racket when the levers are used, also its incredibly weak, like barley lift the loader a couple inches. When this first occurred I stopped and checked oil level which was admittedly low but topping it off didn't help at all. The first day it made the noise while the levers were pulled and then the grinding sorta noise continued for a short time after released, noise was were with higher rpm.
That was a few weeks ago, I hopped on again yesterday and the noise only happened when the lever was pulled and didn't seem to be affected by rpm much. I don't know really what to do but maybe replace the pump (if I can find one)
sorry if this post is a little confusing but I hope someone may have some information for me. Thanks
