Trying to get an old MF up and running again. It sat for several years until I finally got the starter rebuilt. Started up, but no hydraulics. All were working before the starter took a dump. Refiled the reservoir with fluid and most worked immediately. The steering, however, acts like there is no fluid, or perhaps there is air in the lines. Haven't tried to bleed that yet. The additional problem is I have no power to the rear axle. I'm assuming the transmission uses a separate fluid supply. Where does one check/fill that.
Thanks in advance for any help
