trentorosz
Hey there I have a 750 Ford TLB with a 3 speed auto trans
When I start the machine and put it in gear it takes 1-5 minutes of Reving the machine up and down between 700-2000rpm for the tranny to engage and then it takes off with out a hitch for the duration I am using it
If I shut the machine down for 2 minutes and fire it back up i have to repeat the process
I pulled the filter and started the hoe and oil flows very quickly into the housing so it is sucking the oil up I am wondering if there is some sort of bypass that could be sticking or hopefully something that some one has had the same problem and can guide me in the right direction
