Here is the run down of what I have done. I have pulled the distributor set the tack and dwell to zero and adjusted the points to .015 gap. Set the carburetor back to factory settings. Took the battery in to the shop to make sure it was okay and they gave me a new one. Drained the fuel bowel. Pulled the air in pipe off to make sure it is getting air. Pulled number 4 spark plug to make sure I'm getting spark. I am and it is something yellow some times blue in color. I've changed the oil and filer.
When I try and start the tractor sometimes it sounds like it is going to fire then it just rolls over. When I use either I get a hit that it wants to start however it just seam that it can't get there.
Does anyone have any ideas for me? I'll make sure I update this when I get done with each one.
