charr lynn pressure
jr1983
Does anyone know how much pressure is Charr lynn torque generator required to operate properly? I'm wanting to see if I can install it using the hydraulic pump on my 1950 minneapolis-moline UTU?I'm aware that I will need a flow divider to make this work. I also posted a similar question in the Minneapolis Moline forum.
i just looked in my char-lynn manual. the maximum pressure the torque generator is rated for is 1200 psi.
You need flow, the pressure is caused by the resistance to the flow.
They need at least 4 gpm, and cannot exceed 1200 PSI.
