Hi
I'm replacing a leaking lift cylinder and piston on an early model MF202. The cylinder is part 184442M1, the 3". I have a couple questions...
1. Could the cylinder be bored to accommodate a 3 1/8" piston? I'm basing this on the assumption the 3.125" piston they sell for the larger cylinder would work.
2. Could the cylinder be replaced with this different cylinder - 190859M1? This unit is half the price. Says its pressure control, which I don't quite understand and couldn't find an easy answer on. I couldn't find the bolt pattern either.
I couldn't find anything online as to whether any of this might make sense, or too risky...
Thanks!
Thanks!
