Joe-from-MO
Hi everyone. I am once again returning to the well of knowledge to ask a quick question somewhat related to my last post about my tractor that got water in it. The tractor is an IH 674 gas motor and after I got all the water out of the oil I turned my focus to the transmission and hydraulics. The dipstick looked good, looked a little low but clear. Then when I opened the fill on the back I noticed inside the hole about 2 inches down I could see where it looked like some of the "splashing" fluid was a little milky. So I drained it and it all looked pretty good. I'm not too worried about that but I noticed as I pulled the filter off that the bypass screen has a small tear in it. This is the first time I've check it since owning the tractor because the guy I bought it from is a friend and he switched out fluids not long before I got it. The screen had no debris in it so I assume there's nothing too bad floating around in the case so my question is how concerned should I be about the tear? I assume the screen is there to catch anything large before it could enter the filter but I could be wrong. I wouldn't mind replacing it normally but the dealer wants a little over $100 bucks for a replacement and I'd rather not spend it on that if I don't have to. Any advice on the matter would be much appreciated.
