I have 3 gear lube leaks on my 1650, two are on the lower end of the 3pt. arms, it is a little wet from each of these and it goes to the center and drops on the draw bar. Both of these appear to be very small/slow leaks. The third and biggest leak is coming from the PTO shaft. Non of these are gushing leaks and the three of them together hit the drawbar then the drawbar drips in one spot and if I catch this in say an ice cream bucket it takes several months to fill the bucket. Someday I would like to fix them all but for now I was wondering if someone could tell me 1) approximately what is involved and how difficult it could be to replace these seals (I am mechanically inclined and do a lot of my own repairs but have never worked on this before...) ? and 2) For a general purpose chore tractor that is not doing heavy field work anymore would it be that bad to not fix now and run it low on gear lube -- I'm wondering if when the oil gets low enough not to be leaking out of the PTO shaft (the worst leak) is it really dangerously low ? I know I've had it that low before for a short time because I've noticed the leak almost stopped, then I added gear lube back up to the check plug and was right back to leaking. Any advise will be greatly appreciated.
