8n ford tires weather checking
pinball
Is there anything out there that you can use to fill in weather cracked tires. I have a couple tires that work fine but has some weather cracking. Didn't know if there was some thing you could put on them to make them look better. thanks Norm
Not really a lot you can do for them other maybe some armourall or such product. Now if the crack if big there is a filler that you can buy and put in the cracks made by TECH Catalog #858 which is a two part stuff that you use to fill the cracks. But t has a short shelve life and cost over $50 for 2 1 lbs cans
My neighbor bought a farmall cub with a large gash in one tire. He filled it with black silicon gasket maker.
He sold the cub 12 years later. Still had the same tire on it.
Not really sure what you would call it other then a glue/patch stuff made ti fill in cracks etc. It stays soft sort of like what the tire rubber is like
I've seen several people ask about them & have never given it a lot of thought. But after reading some of the posts about the epoxy & stuff, I'm wondering if the liquid electrical tape would work. It's thin enough to run into the cracks and pliable enough to flex when the tire moves. I might just give it a try on a couple of mine. Just my thoughts, Keith
A few years ago I was using some black urethane roof cement in a caulking gun, thought I'd try some in a few tire cracks...force it in with the gun and level it with a swipe from a inch wide squeegee. It's noticeable when done but blends in good after a drive through some grass. Can't say how long it will last, rarely use the tractor.
