AC 5040 gearshift assembly
Joe/Woody
New User
I attempting to locate the correct pin/pins for the gearshift lever.
I do not have a manual (yet) to view a diagram. I have been given conflicting info as to whether it is a two pin assembly. or a single rollerpin. No success yet in finding the correct pin/pins. Nor have I been able to find a diagram as to the design of the shift lever for this AC 5040 diesel. Also this tractor has 6 gears and low/high range. Does that make it a 6 speed or a 12 speed? I would appreciate any help greatly. Thanks
Joe & Woody
Is this what you're talking about? I got the diagram from Import Tractor Parts dot net. I don't know if it means they have the pin or not.
God bless you!!! That's the closest I have seen so far. I attempted www.importtractors.com and the only web site that would display is in spanish. Haven't figured that one out yet. Again thank you for the info, especially the reference for other matching tractors.
Most sincerely
Joe & Woody
(quoted from post at 15:00:46 12/21/15)
Most sincerely
Joe & Woody
RR's site was .net not .com that might be the problem
I have a 445 Long which I believe is the same tractor. Mine has
to pins. I used rivets from a mowing machine section knife to fix
mine.
Correct, .net not .com.
I'd post a link,but I hate to post another site that might be in competition with this host site on some parts.
I would call Rick's ag parts he really
helped me out with mine. Just put a
trans cover on a 1355 oliver today. When
done rebuilding found it is easiest with
it in reverse to place cover down.
