should'vestayedonthefarm
New User
I'm thinking the worst here, I have a 1973 ford 3000 gas that last fall I checked the antifreeze and it was good to -25 deg, so then the next spring I needed to change the oil and rebuild the carb and change a tire but when I went to drain the oil for the oil change and antifreeze came pouring out when I removed the drain plug on the oil pan, the exterior of the block has no cracks and I was wondering if possibly a gasket could've caused this or if I have a cracked cylinder or head, I haven't tore into it yet and didn't know if anyone else had ever encountered this problem, it tested -25 but hadn't been started for about 3 or 4 months prior, Is there any hope for my motor or is it doomed, would like some insight before proceeding so I don't tear it all the way down unnecessarily. :?:
