dgriffiths
New User
I am a Newby to the 8n addiction and need a little guidance. I bought my first 1947 8n a few weeks ago. It has been converted to 12v and has front distributor. I had to replace the radiator, thermostat and hoses along with a new belt and battery. When I put the new battery in it would crank and run. It ran for about 15 minutes before it died on me- I think a fuel problem. That's beside the issue I want to raise right now.
A few days ago (AFTER I ran it 15 minutes before dying on me) I tried to work on it some and when I pushed the starter button the starter would rapidly click as if the battery was not charged. The key had been turned to the off position so I know that was not left on. I put my battery charger on and left it over night. Strange thing- the light on my charger shows "charged" but when I turn the key to the "run" position, in a few seconds the charger light goes back to the "charging" mode. If I push the start button it just clicks- with a one week old battery. The original manufacturer start button is NOT the start button. It's still installed but the PO rerouted and installed a push button under the instrument panel. Is there a way (or should I) cut the wires going to the swith(s) and hot wire the starter just to see if that stops the drain on the battery?[/i]
