John Deere 4430
JWROSS
New User
I have a 4430 that I am pretty confident is in need of new cab mounts. Both PTO and transmission will pop out, particularly if on a bit of rough ground. Inspecting the mounts revealed that they look pretty rough. From what I can read, changing them out should be pretty feasible.
Does anyone have any tips on replacement? i.e. tips on how to, other things to look for, inspect, replace, etc. while in the process?
Any advice is welcome!
If they are really bad, yes, go ahead and replace them.
It's NOT rocket surgery, as long as you do one at a time.
Support/jack/pry as needed, nothing's gonna get out of hand/fall of/tip over while you are doing them one at a time.
I'd think not, as there's no need to lift any corner of the cab very much to change the mounts one at a time.
That being said, I've never done what you are attempting, but have had those cabs loose, or jacked up, or lifted completely off of the tranny and/or rear end repairs.
