super m and mta hydraulic pump
gears and all are ok. plenty of pressure. just have an oil seep where pump housing bolts together. I have an old shop manual that shows an exploded view of pump and it shows a couple of seals inside. it also mentions a seal kit for the pump and I was wondering if anybody knew if they are still available.
Any good hydraulic repair shop can get you a seal kit for those. I dont remember what kind of pump that is but they are common.
I got lucky and found a NOS seal kit for my pump from Bates. All of the seals in that pump are standard o-rings and the two shaft seals are available also. As I recall, the only things you will have to make are two gasket shims.
Dan
