JD Model A 1946, governor
rwinnie
New User
When I try to speed up the governor slows, so I can't add power.
I'm not sure why it does that. Anyone know what adjustment I can make?
If you don't have your problem solved check to make sure that the linkage from you throttle lever and your governor spring isn't touching the casting on the steering support by the slow stop position. If it does it will speed up then slow down when you go to full throttle.
