The injection pump on my 3165 MF backhoe started leaking around the hydraulic head housing where it goes into the main housing. It got bad enough that the tractor wouldnt start SO I decided to do a complete re-seal with rotor blade replacement.
When i pulled the front drive shaft bolt, 2 small 3/8 dia magnet washers with a hard black plastic cap on each end came out with the bolt. THe whole thing is about 7/16 thick.
I dont know why its there? Does anyone know what this small magnet assembly is for or I if should reinstall it in the shaft?
The pump number is 3240F968
