I have a 1954 WD45 that has the following problem:
Starting tractor with foot clutch depressed, will shift into all gears. However, while tractor is running, if foot clutch is depressed and released while tranny is in neutral, the tractor will grind and not shift into any gear.
Also, starting tractor with foot clutch depressed, PTO engages and disengages properly until foot clutch is depressed and released while tranny is in neutral. Then the foot clutch will not disengage PTO.
Everything works fine until the foot clutch is depressed and released in neutral. Any suggestions? Thanks.
