Hello. Recently acquired a case 2090. Have been trying to disk some very hard ground. Seems like the tractor
heats. It has not got into the "hot" area, but likes to stay in the upper part of "normal", I would rather see
it stay in the middle of the normal. I don't think i'm overloading it, pulling a 12 foot tandum disc. I do
need to add 1 to 2 quarts of water/antifreeze each morning, but I figured that was just what was coming out
of the rad when it warms up, maybe i'm wrong. Also seems the rad pressurized rather quickly. The tractors
I've been around usually didn't get that much pressure on them. One it gets warm, if you stop, and let it cool
down, it will cool off in 5 to 10 minutes.
where to start first on these tractors..i'll admit I know more about deere.
I suppose I should blow out the rad.....after that, what's next, thermostat ? hard to tell about the water pump, or do
the guage go out of them ? I've noticed that if I turn the switch off then on, it does a little dance, more
than what I would expect....it goes up a little, then down a little, then shakes a little.
any ideas would be welcome !!
thank you
(also thank you to the board keeper, i forgot "who i was", and my password, and he got me going, again, thank you !)
thank you
