oil wiper ring set position on four groove ford 8n piston
edssonjim
New User
In which groove do the oil wiper rings go in a four groove piston for a ford 8n piston? The envelopes the rings were in had them mixed up.
Edssonjim,The oil ring with expander and rails goes in the third groove from the top.The solid oil ring goes in the fourth bottom groove.Are they new or used pistons,if they are used you MUST! be real sure to check ring (groove clearance).
