Ford 8600 pto trouble
Ford 8600 was working fine. Bushoging with a 15 foot batwing. Took a break, shut pto off and went back to mowing and now the pto acts like it doesn't want to kick in. It just barely spins. Duel power and everything else works good? Any ideas? Any help is apresheated. Hydrolic fluid is milky. Changed 2 times but stays milky
Time to get a manual and check your PTO pressure. The instructions are in the manual. You have seals leaking and clutch plates worn out in the Pto cluch pack most likely. You also need to get all the water out the system and get new clean oil in. You will have to separate the tractor between the transmission and rear end to service the Clutch pack.
