John Canada
I was using a large disc bine when I lost all the hydraulics and PTO instantly so I suspected the pump drive shaft had moved again or sheared. Is this a common problem with these tractors?
Also had this happen about 40 hrs ago, that time when a dealer fixed it, he simply replaced a broken snap rear that had allow the shaft to move to the rear.
This time the snap rings where still in place, two thin ones. I removed them. I threaded in a bolt and pulled out the 4 inch "spacer". I threaded a bolt into the shaft and that pulled rear wards until about 4 inches was sticking out and then it stops solid, I don't understand why.
Any suggestions what may have happened?
