perryjosh64
Folks I appreciate all the help on my issue and "hopefully" getting to the bottom of the problem. Replaced the vented gas cap, sediment bowl shut off valve below the aftermarket gas tank that was leaking as well as the inline fuel filter, the entire fuel line, and cleaned sediment bowl/screen at carb. Then turned around and drained the the carb itself and did the "check flow to carb with pint jar under 3 min" test. I did find that with the new sediment bowl shut off valve under the right side of gas tank that has a screen that goes inside the tank fuel level has to above the screen level to maintain a steady flow of gas to fill sediment bowl?
I'm still a little fuzzy on the "spark" test to ensure I'm getting the right spark to run but left my battery on all night so now gotta wait to recharge it before I can check the spark/electrical.
Hopefully I'll be up and running this weekend!
