hydraulic cylinders won't lift
farmer64
New User
I have a mf 301 cultivator, and had the 2 outside cylinders rebuilt. It has 4 cylinders total, and when you lift it up, 2 of the cylinders lifts up and the other 2 don't, I have tried to bleed the air out of them, and stil can't get it to lift correctly. Any suggestion what I can try now?
there is 1 hose that comes out of 1 side of tractor, and goes to the cylinder on left side, in sequence across to the other 3 cylinders, then back to the tractor.
